Where is the p state 0 setting?
Advanced > AMD (it's at the bottom).
So you using windows in balanced Mode?4Ghz @1.4V
VDD SOC manual voltage @1.175v (will test offset again and may change to that)
Load Line @3 for CPU and VDD SOC
DRAM 1.4V (will try 1.35V)
PLL 1.85V (will try 1.80v)
P State 0 Custom Settings (allows idle clocks and full speed clocks in balanced power profile within Windows!)
FID A0 (change this to adjust frequency, works in hexadecimal, A0 = 4Ghz 94=3.7Ghz 99=3.825Ghz)
DID 8 (don't touch this)
VID 3A ( don't touch this setting, if you need more/less voltage, use CPU Offset voltage in the first image)
4Ghz @1.4V
Thats great stuff Matt
I am waiting my order from OCUK, when ever they have the Taichi in stock![]()
If you think that is good, wait till you see this.
Cinebench @4ghz + DDR4 3200Mhz CL14
Jesus christ......If you think that is good, wait till you see this.
Jesus christ
Is it better to have more Mhz and 2T? Or lower Mhz and 1T? I can get 3000Mhz at 1T with my Corsair Vengeance 3200.
I will give mine a go at 2T and 3200 (or more) then. Thanks! MSI Tomahawk B350 and 1800X is the rest of the spec. My 1080Ti should have arrived at work yesterday so hopefully tomorrow morning it is waiting for me!
Its looking fine so far![]()
The reading from the kraken is 2028RPM Bios is reporting incorrectly........
2*16GB of 3200 RAM running at 3000 2T realistic on better boards?
Not without new bios updates.....2*16GB of 3200 RAM running at 3000 2T realistic on better boards?
