@AMDMatt Would be interested in seeing your new results from handbrake test:
Here are my results:
[19:03:50] sync: framerate min 23.981 fps, max 23.981 fps, avg 23.976 fps
x265 [info]: frame I: 9, Avg QP:20.47 kb/s: 35577.24
x265 [info]: frame P: 487, Avg QP:22.67 kb/s: 9896.55
x265 [info]: frame B: 1001, Avg QP:28.03 kb/s: 901.21
x265 [info]: Weighted P-Frames: Y:3.9% UV:1.2%
x265 [info]: consecutive B-frames: 26.4% 9.1% 11.5% 42.3% 10.7%
encoded 1497 frames in 125.32s (11.95 fps), 4036.02 kb/s, Avg QP:26.24
[19:03:50] mux: track 0, 1497 frames, 31505829 bytes, 4026.03 kbps, fifo 1024
[19:03:50] mux: track 1, 2933 frames, 1252808 bytes, 160.09 kbps, fifo 2048
[19:03:50] libhb: work result = 0
# Encode Completed ...
My results are almost identical.
[19:28:30] sync: framerate min 23.974 fps, max 23.981 fps, avg 23.976 fps
encoded 1497 frames in 120.24s (12.45 fps), 4036.02 kb/s, Avg QP:26.24
[19:28:30] mux: track 0, 1497 frames, 31505829 bytes, 4026.03 kbps, fifo 1024
[19:28:30] mux: track 1, 2933 frames, 1252808 bytes, 160.09 kbps, fifo 2048
[19:28:30] libhb: work result = 0
this was a temperature test against the crappy Cooler Master I had installed.
from here.
