Caporegime
- 7 Apr 2008
- Lorville - Hurston
cycling so much fun.
I currently ride a 2014 Supersix Evo HiMod with Sram Red. I bought this bike last year as it was going "cheap" as it was an old model but one of the downsides are its rear stays are narrow and as such a Gp4000 SII 25mm tyre just fits with careful fitment.
My question is if i was to go for a slightly wider rim internal/external thickness will this increase the width of the tyre itself?
I am looking to get a new set of wheels but most modern wheels are wider.
Probably as Saytan has said. Imagine the cross section of the tyre as a piece of wire looped around. The closer the two ends are the tighter the curve is so a wider rim (ends further apart) results in a wider curve. I would imagine the difference would be small but if things are already tight then it certainly isn't going to help.I currently ride a 2014 Supersix Evo HiMod with Sram Red. I bought this bike last year as it was going "cheap" as it was an old model but one of the downsides are its rear stays are narrow and as such a Gp4000 SII 25mm tyre just fits with careful fitment.
Not me!A whole working week of nice dry weather! Who'd have thunk it![]()
Sheeesh, sorry to hear about that mate, had high hopes they'd just replace it!
Pretty poor 'warranty' then, surprised to hear that from a brand like Cannondale.
EDIT: Surprised but Cannondale 'don't warranty their frames for crashes'. Loads of horror stories of people being short changed by their 'lifetime warranty'.![]()
Ah, you mean who to send it with? I crammed a bike into a box to meet hermes' size limits. And prayed.
Higher weekly mileage than usual? Could just be increased fatigue, if not then it can be an indication of illness starting to show.I started to feel like I had been hammering it for the best part of an hour... Not ~15 minutes! Nothing left in the legs after the short steep bit of Taunton Avenue, gasping a bit a bit for breath, so a prompt warm down and called it a day.![]()
As Saytan mentioned the tyre will 'balloon' a little so the width will be affected a little. Bear in mind the air 'volume' won't significantly change so the overall depth of the tyre (distance from rim to tyre tread) will be shorter due to the wider rim, if you've tight clearances then swapping between tyre manufacturers can make a difference. Mitchelin Pro4 Endurance 25mm were really tight through the bridge mounting point of the mudguards on my Giant Defy and I saw lots of catching and rubbing. Switching to Continental (GP 4 Seasons/GP 4000 SII) gave more clearance. It was a case of as small as 1 millimetre making a big difference to clearance there for me. Many of the older road bike frames were made with 23mm tyres in mind, the more recent trend towards 25mm (and wider rims) can make things very tricky on lots of older frames.My question is if i was to go for a slightly wider rim internal/external thickness will this increase the width of the tyre itself?
Where have you been? Frost here Wednesday morning & bitter cold winds this morning (windchill -2) with forecast high winds and rain for the commute home! Weekend is also pretty much a write off due to rain & winds, FFS!A whole working week of nice dry weather! Who'd have thunk it![]()
Hate to say it, but give MyHermes a go and insure it for the full amount... If you remember what they did with those Northwave boots I tried to send you! (Although check their T&C's as I'm unaware if there's any bike exclusions there)He's suggested Parcel Force so will give them a go. Going to have fun stripping it down for him.
I suspected this much. I will measure the current set of Mavic Kyrsiums and see what i cant get.. not very much i suspect.Wider rims will likely balloon the tyre up a bit.
I think i have the same frame or maybe 2015 version. However, I am running GP4000s 25s fitted to Fulcrum Quattro carbons. the rims are 24.2mm wide. Not exactly sure on internal width - maybe 17mm and clearance is not an issue. Certainly not on the rear. More likely to be an issue on a narrower rim from what my logic would say.I currently ride a 2014 Supersix Evo HiMod with Sram Red. I bought this bike last year as it was going "cheap" as it was an old model but one of the downsides are its rear stays are narrow and as such a Gp4000 SII 25mm tyre just fits with careful fitment.
Rubbish! Well worth leaving a spare at work! I've got several scattered around the place as I ended up with 20 new tubes at one point last year. A fair few have been used and I've started to track them down as I ran short at home (think there's 2 or 3 at my parents place and I've not ridden there for 6 months+!).I've just spent a bit of my lunch hour fixing the inner tube that got busted this morning, so I've got a ready spare in the event that I get another puncture on the way home! That'd be just my luck...
Possible sign that your tyres have had it?There's nothing like fixing a puncture in the pouring rain to remind you why you love cycling.
I got one puncture last year. I'm up to three already this year. Arse.
Nah, only the one today was a legit puncture through the tyre. One was a pinch flat where I fell into a pothole so deep I had to shout up for a ladder to get out. The other was on the inside of the tube, like rimside.Possible sign that your tyres have had it?
