- 23 Nov 2004
I haven't ridden many of them for much distance but I find the spyres to be best of a bad bunch. They line up well, individual pad adjustment means you get it perfect. Massive improvement over the horrendous avid bb5/bb7. 90% of those had to have the lever pull to the bar so that the pad wasn't scuffing.
I've only had one bike that has the same problem as that but on a spyre. OEM caliper(black lever arm) replaced with a retail(polished lever arm) caliper and all was well. Most people just run standard cable but they'll benefit from compression less outer.
Rotors wise the post mount caliper comes with I believe. Flat mounts don't appear to on wiggle.
Make sure you get the correct mounting style 6 bolt(In the name) vs centrelock(like a cassette lock ring).
The trp use a tektro pad(who'd have thought) that is also used on lower end shimanp calipers so you could use shimano rotors of the same size.
Some combinations are weird where the braking area of the rotor is short and the pad is tall so it brakes on the rotor arms which isn't so good.
