PLAYERUNKNOWN'S BATTLEGROUNDS - Thread
I7 4790. GTI 980ti, 16gb ram and my res is 2560x1440. Considering I read that the game is not optomised I've very pleased with the performance I'm getting.
Cheers, i have a 6700k 16GB ram and a 780ti, that i think is almost = to a vanilla 980, and i play only at 1080, so i should be ok.
Performance for me is playable, its only One big town that frame rate drops to un-joyable levels.. Once they sort of the CPU load like said in the blog it will boost GPU performance a lot..
Can always stick this in your launch options guys for higher FPS
-USEALLAVAILABLECORES -malloc=system -sm4
Will drop your graphics a tad (sm4 bit anyway, drops it down to dx10 iirc)
Refunded mine, by the time they sort it out will be on a sale or cheaper I just don't like the way the engine feels at the moment.
Quite like the game but it's just miles away from being optimized so what's the point unless you have an ultra ultra high end rig you're gonna be chugging.
I was watching goldglove he has 5690x and dual titans and he was dipping below 60 fps now and then.It's a very demanding unoptimized game.
I test these two -USEALLAVAILABLECORES -malloc=system on the lobby map each time i managed to make it to part of the map alone for result and for me it made zero difference.
I wouldnt say that I have an ultra ultra high end rig, i5 16gb 1070gtx. I'm playing with everything on high, in 1920x1080 and I'm finding it entirely playable. I'm definitely not chugging.
Running with the rig in my sig at 1080 on ultra with no noticeable slowdowns.
I got a weird memory leak last night, went from average 70fps to 35fps. Rebooted all fine.
Any other option for ADS other than double right click, so annoying to get right when you need to do it fast.
I'm playing with a GTX 1080 and with all settings at the lowest possible the game drops to 60 fps in towns. The devs have said about 5 weeks for optimisation
Getting a solid 60fps with a 980ti at 1440p, mostly on medium, some things on high at 120%, looks pretty enough. I do see that blur though, kinda similar to SQUAD, a Unreal engine thing I guess.
Loving the game, hope it continues to get good updates, as it is, it feels very playable and fun, so it can only get better. One thing I have just decided to do is rebind 'unarm' from x to something else. Preferably somewhere over the other end of the keyboard, Keep hitting the dam thing accidentally in a fight!
God knows how I am getting acceptable performance with everything on high with my system. Could just be that what I consider acceptable to play is lower than most others. To be fair, I dont generally look at the fps numbers, I feel a person can get too obsessed with them, I have a mate who will literally stop playing a game if it drops to 50fps on average, even though I still find it perfectly playable and fun.
I call shenanigans! The game isn't smooth on ultra with the system in my signature, let alone yours!
Perhaps there are slowdowns and I haven't noticed them :p
Very nice, hard to believe that just a 970 can run game that good, how many fps you play at, i like at least 60 constant myself if possible.
Don't know the FPS, if there is no noticable lag on my screen and the gameplay feels smooth, thats good enough for me.
Some people are insanely good at this ! Guy on the leaderboard with 12 wins and 22 top 10s in 8 hours played. When you consider that its say 30mins for a win, which makes the 12 wins , 6 hours. Thats a crazy timeframe. I hope that I can become that good with practice !
Game runs fine for me maxed out at 3440x1440 but I'd be annoyed if it didn't with a 5820k @ 4.7ghz and an overclocked 1080ti.
Really enjoying this game but my fps seems low to me. Running the launch commands as suggested with settings on very low, textures high and only getting 40-60fps with i5-4690k and 980ti.
