JayzTwoCents idle is 50+ @ stock on water? My readings must be ****** as I get 25-33C Idle and 44C when running Cinebench.
Thats what im using.Its because he has AMD Master open, it heats up the CPU at idle.
People experiences of the 1700 in games is good?
I am literally here with credit card before buying.
So far so good herePeople experiences of the 1700 in games is good?
Out of being bored, I have undervolted base clock of 3.2Ghz to 0.936 volts and run reabench H254. Peak temp 38 degrees on air!![]()
Really really wish I could be doing the same!!! My oc'd 7850k is really holding back my GTX 1070. (Everything plays great, I just know it would be a lot better lol)I've just joined the club!![]()
Good here too. My 1700X is at 3700mhz with GTX 1070 and GTA V seems much much better compared to my previous FX-8350 (4ghz) AND GTX 970. I've set MSAA to the max setting and fps doesn't drop below 60 at 1080p. On my AMD FX even if I set the MSAA to X2 it would ocasionally drop below 60.People experiences of the 1700 in games is good?
Isn't that lower than XFR turbo? (which gets disabled when the CPU is overclocked).Good here too. My 1700X is at 3700mhz
I think it is, but I'm happy with the temp/performance balance so I'll just leave it at that until I need more performance, which I don't think I will as I'm already very impressed with it.Isn't that lower than XFR turbo? (which gets disabled when the CPU is overclocked).
