Man of Honour
- 20 Dec 2004
- Tamworth
Aren't the barrels that connect to the actual console a different size?
no, both say the same PSU , and same 9v 1.3A, anyone got a NES confirm this please ?
Yes you can use it.
I used my NES PSU for my super nes, never unwrapped the one supplied with the SNes.
Also photo of a NES PSU http://retrocomputing.stackexchange.com/questions/1607/can-i-use-a-uk-power-adapter-in-ntsc-nes
After listing some items on eBay over the weekend. I did a search for similar items to make sure my listings appeared properly.
That's when I noticed a seller using my pictures on multiple listings.
I'll post a link to one of the items and you can then check all the items they have for sale. I think I can safely say that it's unlikely that they have multiple copies of each of these games and if you are watching or bidding on them, then it's unlikely you'll get the item.in question.
The listings they've copied of mine are for all 6 Final Fantasy games on PS1, Chiki Chiki Boys on Mega Drive and Ecco, Star Wars and Night Trap on Mega CD.
So beware guys.
I have reported it to eBay as well.
http://www.ebay.co.uk/itm/152486573860
is he just using your pictures ?
ive done that on some comics (saves me taking a photo) but the products are identical and i was selling them
want to to bid high and pay, and see if i get it ?
EDIT/
hes got loads of multiple listings , for different items
thanks
the seller i bought the nes from told me a snes psu wont work, and he tested the nes, before shipping, but it doesent work (flashing red light) tried blowing contacts etc but to no avail
ill return it then![]()
One small snippet of knowledge here, the NES should work fine on a SNES PSU however not necessarily the other way round.
The UK SNES uses a 9V AC adaptor and will work fine with a DC PSU, however there are DC only console versions (JAP/US I think) that can die quite nastily if you connect an AC PSU to it.
(to do with the lack of a bridge rectifier to handle the AC current)
I used to work at the one in Chatham for a couple of years, used to visit after school when it was Future zone.. A couple of times at the Maidstone one too.I remember EB in Canterbury, where I picked up Tekken 3, was so excited that day.
