I've always been confused by the terminology used in OBS to be honest mate. Just fired up mine to check what I use (changed a bit since I made that vid). Seems I use game capture when after games and target a specific .exe, but I do remember using display capture in the past when game capture failed me.
From member if you alt-tab whilst using game capture you'll likely bork your recording, but that's less likely to happen in display capture. At least from my experience and I break my recordings frequently by doing that..![]()
I had a bit of a tinker with this over the weekend and found that setting it to game capture seemed to do the job. I also added display capture into the source box as well, though now I come to think of it, I can't quite recall which way round I prioritized them.
I like that it records one larger file than, for example, ShadowPlay - which breaks the recording up into smaller segments, though I understand you can do something similar where the latter is concerned, I just haven't got around to testing it properly yet.
As for performance when recording, I have a very limited experience so far but there did seem to be more of a performance drop than compared to SP. This wasn't evident so much in terms of fps, but more by way of how it 'felt', which is a little odd. That said, it's likely I haven't set it up optimally, so it could well be a case of user error. Too early to say.
All in all, an enjoyable experience & if anyone gets a moment, then a quick check of the following would be appreciated. Thanks for doing the video; I certainly learned a few things there though it might not be what I am after just right now, but I could see myself using those programs more as time goes on. Btw, that's a very nicely produced video.
I should have added that when I recorded using the steps in your video, it still only gave me one audio track despite me checking more than one box in the relevant options menus (ignore the fact that I've only got a single audio track checked in one of the above pics). Obviously, I must have done something wrong, but I don't know what yet.
