- 14 Dec 2010
- Nottingham
Ask him if he's bored with life to the extent he needs to aggro you. Then threaten violence. Usually works.
I think OcUK should have a collection for your neighbour's letterbox.![]()
That's far too close to the fence I hope the guttering doesn't get blocked up. I think whilst legally there is nothing wrong I'd be miffed if I was your neighbour
If the neighbour builds one as well you can change from a detached to a link detached...
How are you ever going to maintain the side against the fence?
Too close to the fence? Nothing is touching the fence, the guttering, the whole structure, is all on my side of the fence. Both houses have guttering and soffits so not much rain would even get through to that area anyway.
Why would you be miffed? The bit closest to the fence is less than an inch higher than the fence post.
To be fair you've jammed something into a space. It looks garrish the gutter is right up against the fence which appears to be leaning from the pictures coming from Chatham I'm suprised he's not gutted you
It looks fine. People who get annoyed about this sort of thing are looking to butt heads more than anything else. If you give into what he says, you will hear back from him soon enough with some other demand or grievance.
The wood on the fence looks like it has a bit of a lean but it looks like it could be down to the wooden fence warping as much as anything else. If your neighbour is fussed about the leaning, then inform him that you luckily have a sturdy new structure to fix the fence to.
isn't there some sort of maintenance access requirement? like needing to leave about 1m around a property - does that cover fences too? i guess it will never get treated...
It does look a bit stuffed in tbh, but as long as its below the 2.5m(?) limit then he can do one.
The biggest annoyance to me would be the wonky as **** visible fixings, well that and the entire door looks to be slanted![]()
