Man of Honour
- 20 Dec 2004
- Tamworth
To save future members reading the whole thread I've since purchased a Denon AVR X2300 and the speakers I had sound better with it than my previous amp so the actual question I asked has been answered.
I recently bought a Denon AVR X2000, a set of Q Acoustics 2020's, 2010's, 2000C and a BK Gemini II sub from the MM.
I knew at the time that my wife wasn't happy with the walnut finish of the speakers, that the rears would have to be wall mounted and fitting the front speakers on their stands in the space available would be difficult at best.
As it turns out non of the above worked out and I reluctantly sold the speakers, keeping the amp and the sub.
I then bought a set of Q Acoustics 7000 satellites from eBay. They were well reviewed and, just as important, my wife likes the look of them and they are easily wall mounted. I didn't realise at the time that the Q7000's had been replaced by the 7000i's but I'm happy with the sound so everything should be good.
Sadly no.
During the same time as buying the amp I swapped TV provider to Virgin Media so I now have the new V6 box which is where the problem lies.
Basically my amp isn't HDCP 2.2 compliant so I'm more or less excluded from 4k/UHD going forward, since the V6 box is HDCP 2.2 and so it seems is every other 4k capable piece of hardware. Now do have a mid range 4k TV and nearly bought an Xbox One S last week with a view to getting a few 4K Blu-ray films. But after some research I found out that I'll need HDCP 2.2 to run it through my amp.
So the question is (finally a question) will the speakers I have be a decent match for a Denon AVR X 2300? I'm thinking of selling the Denon 2000 amp while it's still worth selling and replacing it with the 2300, which solves all the HDCP 2.2 ball ache going forward.
Or should I stick with what I have and forget about 4k for a year or so before going back to Sky and the possibility of more widely available content?
If you've read this far then thanks for any replies and apologies for the winding preamble.
Sadly no.
