- 25 Nov 2011
- The KOP
Report link opens for me.
Any idea what to do about the error "Default Radeon WattMan settings have been restored due an unexpected system failure"?
I upgraded to the latest driver this evening...
@AMDMatt - the Report AMD Driver Bug link isn't working.
Also, are you getting many reports of Player Unknown's Battlegrounds crashing on RX 480 cards? I simply can't get mine to run stably.
Are there any resources you can point me toward?
Thanks for the reply. I've tried 17.4.1, 17.3.1 and 17.2.1 and the game crashes with each. Essentially it is unplayable with the RX 480 with my system and card even at stock settings, as I can't complete a round unless I die early.On 17.4.1? I'll check it out.
Not seen any reports, but that game is not released and buggy/unoptimised from what I've heard.
Yeah I was only getting this error under 17.4.1. I have since gone back to 17.2.1 and that particular issue has stopped occurring.I'm getting this on every boot. Not even overclocked.
This is on a RX480 and it didn't do this on the last drivers.
I've tried stressing my system in every way to see if it would reveal instability or issues under other circumstances; I have run Memtest for 12 hours and run the Unigine Heaven demo at ultra settings whilst running a custom Prime95 test concurrently for 4 hours. Both have been error and crash free.
It's frustrating as performance is good and much better than the nvidia card it replaced! Please let me know if I can report my issue somewhere. I know from the Battlegrounds forums that other RX 480 users are having problems too.
17.4.2 is out in the wild.
If Freesync seems to be broken, ensure display scaling is set to 100% by...
Right-click on desktop
Display settings
Custom scaling
Change value you see to another number and hit apply
Change number again to 100 and hit apply
Hit the sign out now link
Interesting.. is that something you found out yourselves or did you read it elsewhere? and thanks for sharing btw.
Any release notes for the new driver?
Radeon Software Crimson ReLive Edition 17.4.2 Highlights
Fixed Issues
- Initial support for Windows®10 Creators Update.
- SteamVR Asynchronous Reprojection feature may not function or enable correctly on supported hardware.
- Battlefield™1 may experience poor scaling in Multi GPU mode using DirectX®11 API.
- Radeon ReLive may experience flickering when recording with an extended display connected on Windows®7 system configurations.
- Application profiles in Radeon Settings may fail to retain after system log off or reboot for some gaming applications.
- Windows® Security popup may be experienced after install and reboot on some Hybrid Graphics system configurations.
