**Nvidia GeForce GTX 1080 Ti Thread**
19 Apr 2014
The Nostromo
well customer service have made me a happy chappy after my order issues :) 2 x zotac AE on the way when the next batch comes in :) currently 8th in line for my cards
see after the problems i had this is exactly why i keep coming back to OCUK (well and the fact there a 15 min drive lol)
6 Jan 2011
Stoke on Trent
Thats one reason I use them living local delivery is great but having to fit your day around collection is a pain. Though have to resist buying other toys when in the shop.
19 Apr 2014
The Nostromo
your not alone there buddy :)
i try to occupy myself with the haribo on the counter and some light gaming on the display models by the entrance to divert myself from more SHINEYS wile i wait for my stuff :)
17 Mar 2017
Manchester
For the one that thinks I'm imagining it when i say i can't hear the fans on the amp extreme even when pushing it source tweaktown
"When it comes to cooling, ZOTAC is king - at 2GHz and 12GHz for the GPU and GDDR5X, respectively - our card was hitting 67C maximum with the fans barely making any noise at all"
Maybe I'm going deaf and can't hear them lol.
25 Aug 2015
This I don't agree with, and its actually making me consider cancelling my order. Why should people who order different cards be put in front of other people's orders because they change their minds? If you change cards then you should go to the back of the queue for that card.
30 Nov 2011
You dont have to make veiled references lol, there is a quote function.
Tweaktown dont do db testing and they've only tested 2 cards even. Other sites do and place it with 1db of other custom cards.
I didnt say you were imagining anything, just pointing out that without an actual comparable test, you paraphrasing tweaktown saying "my purchase was the best because a reviewer said so without any actual test results to back it up" doesnt actually hold much water.
I'm not saying the amp extreme isnt a good card, it just seems overpriced compared with other cards that can do 2050mhz at around 40db
19 Apr 2014
The Nostromo
wasnt really a case of changing my mind was more sacrificing the card i wanted for another. i was due to be in the first wave of STRIX cards and i was pushed out of the que due to not having both my items in stock at the same time and missing out id rather have my strix and the zotac but if i stuck with my order id prob end up going with out either for months my preorder was made on the 13th march for both
17 Mar 2017
Manchester
You made an assumption that because 1 person says his pc is quiet and sounds like a helicopter that nobody is correct ? I've never owned a zotac card before but helping others with their decision, the amp extreme has the thickest heat sink I've ever seen and shows it's not there for show because I've never felt so much heat coming from a gpu that on mine anyway sits at 66c at full load, the hest sink is doing a fantastic job of dissipating the heat away from the core.
25 Aug 2015
wasnt really a case of changing my mind i was due to be in the first wave of STRIX cards and i was pushed out of the que due to not having both my items in stock at the same time and missing out id rather have my strix and the zotac but if i stuck with my order id prob end up going with out either for months my preorder was made on the 13th march for both
It's really not that relevant, in the end your order was put before others who ordered that card before you. I'm not having a go at you, it's the system OCUK are using that is wrong.
