- 17 Jun 2012
- South Wales
Yeah that's what I don't like.Thats nonsense, M Sport and AMG are as much trim levels as anything meaningful about performance these days.
So what's your take when a none M car has very good performance? Even surpassing previous m car performance?Yeah that's what I don't like.
I just believe that M and AMG . etc badges should stay on the performance cars of each range and not just be a trim level. Although I understand why manufacturers do it.It's still not a proper 'M' car. Simple as that.
Doesn't matter how it compares to previous generations - what does that have to do with where a vehicle sits in the manufacturers current range?
Not quite.
M Sport =/= M
AMG Line =/= AMG
Distinct difference but often overlooked.
Again you're using the term performance car which has been bandied about. Is a 340i not a performance car? It's very quick. Handles very well.It should be limited so the M badge drivers can still feel superior.I just believe that M and AMG . etc badges should stay on the performance cars of each range and not just be a trim level. Although I understand why manufacturers do it.
Exactly. So you could have an m car with worse performance than a none m. Just because they're trying to appeal to different market segments.The fun part is it's whatever Merc and BMW says it is![]()
Define 'proper m car'.
I'm not comparing across generations at all. Compare an m5 vs an m140i for example around a track.A car with a designated 'M' number. Not M Sport trim or M tech add ons.
You're comparing across generations again. An 'M' car isn't an 'M' car just because of it's performance.
I get the appeal of having a sporty looking M Sport BMW. But it's not an 'M' car.
To be fair you can get 'msport/amg' package on diesels direct from the manufacturer now. I do agree it's stupid though.
Call it a sport or do something different, don't make it look like a fake M/AMGSo what's your take when a none M car has very good performance? Even surpassing previous m car performance?
Still not at M car...Again you're using the term performance car which has been bandied about. Is a 340i not a performance car? It's very quick. Handles very well.
The M5 wins... although it's brakes will fade quicker if it doesn't have carbon ceramicsI'm not comparing across generations at all. Compare an m5 vs an m140i for example around a track.
That makes me laugh at them because they've sacrificed torque to make it "more sporty" heheheBog standard every day cars with massively loud aftermarket exhausts.
Stupidly loud exhausts are annoying full stop but when it's on a 1.0L Corsa it just winds me up a bit more.
