- 19 Feb 2007
- Northampton
Seems the creators update messed with DSR, Can no longer select resolutions higher than my monitors native res in games.
What resolution Smogsy? Im hoping 1440pcreators update fps increase
Before
Witcher 3 Maxed settings (Hairworks AA set to 4x not 8)
Lowest FPS 55
Average: 70
High: 83
After
Witcher 3
Lowest FPS 57
Average: 80
High: 102
Feeeewwww Im playing at 4k and was like "WTF?" my frames are no where near that!Yes.
1440 UltrawideWhat resolution Smogsy? Im hoping 1440p
Cool Cheers. Im getting around 55 - 60 fps in the middle of a forest in Ultra with full hairworks and no AA1440 Ultrawide
anyone know how to fix DSR since win 10 creators update.it lets you select the resolutions but ingames it doesnt .
Anyone noticing that skype now sets the GPU to a high gpu clock and mem clock ?
This happens when you turn your camera on and you will see the clocks go to almost full speed for core and memory and will stay there and will not down clock untill you turn the camera off again. The camera I have is a Logitech C920 HD 1080p . It is really annoying it is doing that while using skype it only does it when you turn your camera on, does not matter if the other persons camera is on or off.
On the latest drivers and latest skype here. I did upgrade to windows 10 creators update too, but it was doing this before the windows 10 update and the latest nvidia drivers that are meant to be compatible with creators update.
It use to run skype at the idle clocks before but seems to be doing some hardware acceleration now on the GPU or is tripping the GPU drivers to set very high clocks for core and mem for no good reason, it is basically behaving like a power virus and making the GPU run warm for no good reason.
Just a note too, I did try the Logitech drivers from Logitech and the ones windows 10 can install too from Microsoft and both behaved exactly the same. Also did a reinstall of the Nvidia drivers (clean install) and skype to rule them out too.
Maybe a new headache they did update skype a few times recently and maybe one of the updates to skype is now doing that, have not rules out an older version yet that may stop it.
Gotta wait for a new driver, The creators update borked DSR annoyingly![]()
GeForce Hotfix driver 381.78
This is GeForce Hot Fix driver version 378.72 that addresses the following:
-Fixes Windows 10 Creators Update booting to a black screen on certain notebooks
Choose the appropriate driver according to your Windows 10 version:
Im getting graphical corruption with latest drivers and wind10 creators update at first boot - get weird graphical glitches and then black screen.
Powering off and starting fixes this.....
Never had this issue before so not sure if its win10 update or nvidia update.... Hopefully will be fixed soon....
