Official RX580,RX570,RX560 and RX550 series review thread
Sad times for AMD when this is what they are producing:
https://www.techpowerup.com/reviews/Sapphire/RX_580_Nitro_Plus/31.html
Nvidia at around twice the performance per watt, that is more than occurs with a full node drop, more than occurs in a whole new architecture generation.Sure, as a consumer you may not care but it is a useful indication of the relative normalized performance level between AMD and NVidia. Now even if Vega magically can offer twice the performance per watt, which would be unheard of for the same node process, that puts it at about the same performance and power as Pascal, released 1 year later.
The most shocking thing in that link is that it is only about ~10% faster than a 390 across all resolutions and not a huge amount more power efficient either (about 30% more). When you take into account that you could have got a 290x for the same price as this (or less) over 2 years ago it is pretty damning on the progress they have made.
The only thing wrong with 580 is the pricing. It should be closer to £200 than £300! Had these come out as a direct replacement giving slightly more performance than a 480 for the same price it would have been fine.
So how did AMD manage to make Polaris, a 14nm part, perform worse than even the Fury, a 28nm part (perf/watt)?
to be fair Rx 480 was aied at gm204 (970) this time rx580 is aimed at gm204 980.
Amd are still a couple of years behind with Polaris, maybe vega will turn it all around.
Heart breaking for any GPU tech fan.
Using a smaller GPU than the last gen and trying to match it with higher clocks, when you overclock your CPU or GPU your power consumption goes up exponentially, that's what's happening here, at 1100Mhz the power consumption on these chips is probably pretty good, at 1266 its not, at 1340 its just plain bad.
That one fact has highlighted how AMD have fallen in the gpu stakes :(
Wow so much doom and gloom in here.. The only thing wrong with the RX580 is the price and that is certainly not all on AMD. There is price gouging going on. Some of the rx 580s here in Denmark are only 20 quid cheaper than the 1070. That does not match the advertised MSRP.
And for those of you screaming from the rooftops that its so sad that it just about overtakes a r9 290x or just about matches a 390x well there is a clear difference in what kind of products these are. The R9 290x was a top end GPUs when it launched compared to the RX 400 and now 500 series which are mid end GPUs. So for you to be able to get a mid tier GPU that can match a last gen top end for less money on release day is not that bad a thing. Heck if you are to believe Gamers Nexus's benchmarks it even overtakes the fury and 980ti stock on a rare occassion.
