- 21 May 2010
I phoned up today and they gave me infinity 3 for £47.49 a month inclusive of line rental. Thought that was great value considering what else is out there.Yup, but we cant do anything else
It says 160 and upto 200 but in practise anything between 120-150. When I first got it it was a stable 220 but looks like they've changed the speeds.What speed will you get for that? 200?
Can't say I've noticed anything..
Give me some sites to try at my end.
As misschief has said, its unfortunately a waiting game. I had to wait over a year once i'd moved into my current property. One thing to note is that even though i was on a "waiting list", they did not notify me when capacity was available. I only found out by regularly checking myself.If the cabinet is full then you'll either be waiting for someone to vacate a space by moving house of changing over to Virgin or a DSL service. Keep an eye out for any 'Sold' signs and check daily.
There may also be a small possibility that extra capacity may be planned or installed but this doesn't happen that often.
Has anyone bought a second youview+ box,say from ebay or somewhere similar and used that with their existing tv package on top of their existing box?
I have. You can't run the likes of BTsport or the iptv channels on both boxes at the same time as it knows your connected and setup on a box already. Not sure if you can pay extra for a second slot.
Newer box is much slicker though
Depends entirely on the area.How often do BT cabinets become full?
Must be common as ive seen it a few times on my local cab.How often do BT cabinets become full?
You're probably mixing up bits (b) and bytes (B) (8 bits to the byte).
40Mbps = 5MBps (40 / 8 = 5).
