Premium fuels. Hidden benefit
Well my M3 with active spark management through ion sensing certainly can benefit from higher octane
Don't think anyone is disagreeing?
Hence my comment about depending on the engine
Nope because you made the blanket statement that all engines will return more MPG if they are capable of using higher octane?
Why is everyone arguing with me ?
Because the majority of your posts are open ended one liners
But you would need to present evidence it causes air/fuel ratio problems. Not that it looks ugly.
Brakes look terrible after a while and yet perform fine.
I think engineering explained presented the evidence on this. I'll find it to show here.
It effect the flow into the combustion chamber. The end
How about you guys look at the pictures and realise a lot of people word hard to make engines look like that and it's not just witchcraft
When did I say that? I said if the engine can benefit from high octane it will get higher mpg
All engines are capable of using high octane fuel!
I thought we established that the pictures refer to a apecific indirect injection engine that hasn't been used in any cars since 2010?
Care to show pictures of premium fuel doing the same for direct injection engines? Assuming we can base everything on how things look.
All the Shell literature also always refer to improvements in port injection engines.
Many cars haven't moved to DI. The car parc in mainly port injection still
It's not an argument to discredit the effects IN port injection engines by starting to bring in direct injection counter arguments
Not disputing the cleaning effects in port injection engines. Disputing the actual benefit (engine manufacturers are aware there will be some carbon buildup which reaches an equilibrium, DPFs, EGRs etc. all have some build up as well which can't be helped). Assuming I concede that for a second anyway.
Are we saying the benefits these pictures are showing are not what you will see with DI engines? Yes?
with everyone switching over to direct injection, it won't actually make any difference as the fuel doesn't hit the valves anymore
Anyone even used port injection in the last 5 years?
Suburu have actually gone back to using port injection alongside direct injection on their current engine, to prevent buildup.
Actually a lot of manufacturers are now switching to a duel injection system (VAG, Subaru, Ford and others). It's not to prevent build up of carbon, though. It's actually to meet Euro 6 and above emissions regs. Direct injection is more efficient, but it's very dirty indeed compared to port injection. Newer dual injection systems use direct injection to stabilise idle and at full load, and port injection the rest of the time. The fact this gives the inlet valves a good wash and clean is just a happy side effect.
Simon, I understood the spirit of your post and I agree with it. Carbon deposits even on DI vehicles (injectors etc) will rob combustion efficiency and even affect the air:fuel rate by absorbing fuel from the mixture. Keeping injectors clean is no bad thing, and for the small extra cost compared to everything else you pay for in running a car, it'd be daft not to use the best you can really.
My car returns around 10% better MPG on 99 RON, but it was designed for such fuel. @Armageus you said a car might provide more power rather than better economy on high octane / premium fuel, but surely to a degree they're interchangeable? You either make full use of the benefits (e.g. ignition advance) and gain more power than on 95 RON because you planted your right foot, or you used it to gain MPG by getting the same power as before but with less throttle? :)
I've used V Power since I bought my car. It's a turbocharged direct injection engine so if it helps keep things a bit cleaner and generally helps get the best out of it, then the slight increase in cost is worth it to me.
I was curious about this and found a copy of the E46 M3 manual for the USA model which has 333BHP. Compared to the UK one (343BHP), the manual says that the engine is designed to be run on 91 octane premium unleaded fuel. The UK/EU manual says it is designed to run on 98 octane. There are no physical differences between S54 engine in either market otherwise.
Does the octane of fuel differ between Europe and USA then? Or is this how BMW met the regulations for the US market by adjusting the ECU for 91 octane vs the EU version's 98, and thus resulting in 10HP difference?
The mapping will be different to make use of the different fuels. Petrol in the US tends to be lower quality in places.
But also, manufacturers have been known to fudge official figures to get lower tax bands etc :P
If I remember correctly, I used to have this stuff in my head, but the UK cars are 338bhp and 343PS
But also, manufacturers have been known to fudge official figures to get lower tax bands etc :p
In the US they use AKI (anti knock index), sometimes called PON (pump octane number) which is worked out with RON x MON / 2. Roughly:
86-87 AKI (91-92 RON) for regular
89-90 (94-95) for mid-grade (European Premium)
90-94 (RON 95-99) for premium unleaded or E10 (Super in Europe)
Ah that makes sense. So largely not much difference then with conversion considered.
Probably right, but it's not helped by literally every piece of written material using one or the other :p I know mine made 337.7hp on dyno,
90 is standard in the US with 95 being premium. But it also varies between states.
They don't use Ron but AKI just to confuse you further.
The US cars may have the same engine but different map.
