Permabanned
- 12 Sep 2013
- Knowhere
Full RGB of course.
It'll be interesting to see what they do with Vega cooling. The Fury boards were quite short due to not needing the extra VRAM chip space (I assume). I guess an air cooled version without a blower would just need to have a cooler significantly longer than the card.
So basically what the Fury Trix from Sapphire was like, Like all the other Fury Pro's it had a 3 fan cooler with one fan and a third of the heatsink being past the board and backplate which had the added benefit of allowing the third fan to push air through the uncovered heatsink a lot easier.
That helped the card run cooler and quieter as seen when comparing it too the Asus's Fury Strix which had a full length custom board and backplate, On the Strix temps were a few degrees hotter even though the fans were spinning faster creating more noise.
Based on that I hope we can get similar coolers for Vega with a large chunk of the heatsink out in the open..
Common sense often goes out the window on these forums.I saw it here on these and many other forums where plenty of people complained and said AMD should do better. Granted Freesync was new and many didn't understand the spec, how it worked or how AMD was involved. You would think however that it would compel people to do some research instead of just repeating what a random guy has said in frustration and ignorance.
