Lidl gives a 3 year warranty with it - Does Screwfix ? I could only find the 3.6kg drill at screwfix and that will be a bit heavy for most small jobs - I also have a 5kg for big jobs and you do not want to take one up a ladder.
I would use a angle grinder if joins are long ones - but I have also found if you can lift the slabs (or are they bricks) I then clean them with wide chisel and hammer - saves damaging them.
ps - the Lidl drill is 2.5kg -not much bigger than normal electric drill and mine has been fine - can't comment on Titan
