Better traction I think. I rarely use karts, and stick with the Vespa most of the time![]()
If you use tilt controls you get near max traction no matter what your kart choices are.
I see... i dont use the tilt controls. I have the steering wheel accessory so might give it a go.
Create a kart combo that sacrifices traction for speed or acceleration and use tilt controls. It gives you a nice advantage.
Press the + button on your switch and it'll bring up stats.I didn't even realise the choices of karts and tyres etc actually has an impact on anything other than how it looks!
Also, it shows whether you have auto steering on... hopefully you have that off?
I'm gunna stick with my analogue stick and pipe cart![]()
By the way, how's everyone been playing this in the races so far? Handheld, TV + Pro Controller etc.?
I've just been using it handheld so far (gf's bagged the main TV in the evening) and it's been okay - I have a pro controller but haven't raced against anyone with that yet.
Portable mode with either the joy cons or pro controller.
I'm also surprised at how comfortable the pro controller is.
So does using tilt controls have a disadvantage at all other than having to get used to them? (I wont be using them regardless)
If not, that seems a bit of an unfair advantage if traction really is maxed, unless your overall control is less precise so that counter balances that.
