Galaxy Note 8 Specs
Source - GSMArena
- Body: Polished aluminum frame, Gorilla Glass 5 front and back; IP68 certified for water and dust resistance. Midnight Black, Orchid Grey, Deepsea Blue, Maple Gold color schemes.
- Display: 6.3" Super AMOLED 'Infinity Display', 2,960x1440px resolution, 18.5:9 (2.06:1) aspect ratio, 522ppi; HDR 10 compliant (no Dolby Vision).
- Rear camera: Primary 12MP, Type 1/2.55" sensor, f/1.7 aperture, 26mm equiv. focal length; Secondary 12MP, Type 1/3.4" sensor, f/2.4 aperture, 52mm equiv. focal length; dual pixel phase detection autofocus and OIS on both; 2x zoom. 2160p/30fps video recording.
- Front camera: 8MP, f/1.7 aperture, autofocus; 1440p/30fps video recording.
- OS/Software: Android 7.1.1 Nougat; Samsung Grace UX; Bixby virtual assistant; Smart Connect, Smart Connect Home
- Chipsets: Qualcomm Snapdragon 835: octa-core CPU (4x2.35GHz Kryo 280 & 4x1.9GHz Kryo 280), Adreno 540 GPU. Exynos 8895: octa-core CPU (4x2nd-gen Mongoose 2.3GHz + 4xCortex-A53 1.7GHz), Mali-G71 GPU.
- Memory: 6GB of RAM; 64GB of storage; microSD slot for cards up to 256GB, UFS cards support.
- Battery: 3,300mAh Li-Po (sealed); Adaptive Fast Charging (same as S7/S8); QuickCharge 2.0 support; WPC (Qi)&PMA wireless charging.
- Connectivity: Single-SIM, Dual-SIM available in certain markets; LTE-A, 4-Band/5-Band carrier aggregation, Cat.16/13 (1Gbps/150Mbps); USB Type-C (v3.1); Wi-Fi a/b/g/n/ac MU-MIMO; GPS, Beidou, Galileo; NFC; Bluetooth 5.0.
- Misc: S-Pen stylus with 4096 pressure levels; fingerprint/iris/face recognition; single speaker on the bottom; 3.5mm jack; bundled AKG headphones.
Previews/Reviews
Additional Information
Release date
The Samsung Galaxy Note 8 went on sale in the UK just moments after its unveiling and will start shipping on 15 September.
Price
Samsung's own website has started taking Note 8 pre-orders. The smartphone, along with a dual-SIM variant, can both be picked up for £869 SIM-free.
Source - TheINQUIRER
- Carphone Warehouse has started taking pre-orders for the Galaxy Note 8. It's on sale for £869 SIM-free, and the retailer is also offering handset on tariffs with EE, iD, O2 and Vodafone, with prices starting from £56 per month for a 24-month contract with 10GB monthly data. It's also throwing in a free DeX station worth £139.99.
- EE is also offering a free DeX dock to those who pre-order before 14 September. The firm is recommending its £62.99 per month tariff, which comes with 15GB data and an upfront cost of £49.99.
- O2 has been quick to open up pre-orders. Over on its website, the Galaxy Note 8 can be picked up for £49.99 on a choice of £56, £66, £76 and £96 (!) tariffs, which come with 3GB, 10GB, 30GB or 50GB monthly data.
- Three is taking pre-orders, and is also chucking in a free DeX dock. It's offering 1GB data for £48 per month (with a £99 upfront cost), 12GB data for £56 per month (£79 upfront) and 100GB data for £64 per month (£79 upfront).
- Vodafone has started taking orders for the Note 8 and, surprise surprise, is also offering a free DeX. Prices start from £44 a month with a £300 upfront cost, which gets you 500MB data and 500 minutes per month. If you're after more data, Vodafone is offering 16GB and 32GB for £60 and £66 a month, respectively, with a £50 upfront cost.
Tips & Tricks
Background/ad-free YouTube (non-root method)
The XDA thread is here. I did the following to get it working:
All working fine here and in black
- In the Mediafile directory - navigate to the 12.40.59 folder
- Then the non-root folder
- Download appropriate APK (either black or not black)
- Install the APK
- To fix the sign in bug, download the microG app found in the root Mediafile folder and install
- Sign in through the modded YouTube app (it should appear as a separate app to the original YouTube)
User tips
- In Developer Options - change the animation scales (3 instances) to 0.5x for a smoother feel
- Install Package Disabler Pro - this is a handy app that disables a lot of bloatware (and more if you wish)
- Install Greenify - which puts unused apps to sleep
Android 8.0 - Oreo
It appears Samsung have begun their months long process of seeding 8.0 to the Exonys N8s in France around mid-March 2018. Users can manually flash the official 8.0 ROM without tripping KNOX, or just wait until it seeds to you (but for some this could be a long wait). Everything you need to know can be found here (thanks Cosimo) and please note, if you flash - you flash at your own risk but it's a fairly simple process. Fast working download links (painfully slow on Samsung's website otherwise) can be found here for the ROM. Please remember all of this relates to the Exonys version of Oreo.
Android 9.0 - Pie
This will be the last major update for the Note 8, should start seeding from February 2019.
Thank you to @Funky-Melon for notifying us about a way to get the Pie beta. If you have the 'Samsung Members' app you can get Pie beta installed now. You may need to restart for the update to show when you do a manual check for software updates.
