no, this -;https://www.amazon.co.uk/d/Car-Sham...982&sr=8-1&keywords=autoglym+bodywork+shampoo
This for a foam lance I've bought?
https://www.amazon.co.uk/Bilt-Hambe...TF8&qid=1493980423&sr=1-24&keywords=snow+foam
This video doesn't look very foamy?
Doesn't need to be foamy, it's cleaning power is unreal it just draws all the dirt right off the carI like TDGs at the moment however:
UC & 105 are really good compounds, but you'll want to use a refining/finishing polish to bring out the gloss. The 3in1 will cut, finish and lay down some protection all in one. It's a real good product for a short space of time.Thanks.
Would that be better than Ultimate Compound or Meguiars 105?
TDGs ?
Meguirs Gold Class is my current favourite.
Must admit that was my conclusion when I tried TFR a while back, plus wasn't sure about it stripping wax.Watch in amazement as the car gets absolutely covered, convincing you the stuff will work a treat.
Before washing it off and seeing absolutely no difference
In fairness it does loosen stuff a bit
