just no. how did you come to that conclusion.So now every company purchasing software needs a team of developers to audit the code. Why wouldn't they make their own software at that point? The cost would make it unfeasible.
did you miss the last dozen posts, yes it would and it would take a long time until it could be enforced, and as I said that is why it should be done asap.
There's nothing fundamentally wrong with applications running on mainframe systems and accessed via terminal emulators, let's not get the idea that newer always equals better.Ive seen the old green on black stuff - emulated on machines because the "app" was never rebuilt
nope, again I said like a decade, so I think you are just failing at reading.Point was I think you are massively underestimating the shake up it would require to the law as well as logistically and how whole rafts of interconnected industries work - it would be 10-20 years or more before what you are talking about would be feasible in the slightest.
did I say have it for everything?What good is the source code if you don't fully understand it?
NHS is not only using Win 7 and XP but it's not uncommon to see Windows 98 on ECG machines and other built ins. And for a good reason. We live in terrible times of enforced product obsolescence. A multimillion fleet of 2012 computers with Windows 7 would lose security updates just three years later because Microsoft decided end consumer and millions of machines in government and healthcare places just weren't worth their attention. Multimillion fleet of perfectly good cardiographs or ultrasound scanners from 2012 wouldn't get drivers to work on Windows 8 or Windows 10 because it was unsustainable for developers to maintain such wide span of OSes. Databases wouldn't support both old and new OSes. It's virtually impossible for organisation like NHS to keep up with lifecycles this short. And good that they don't chase those scrooge EOLs. Windows 8 will stop updating next year. Windows 10 forced onto everyone on earth will stop updating in 2020. By the time NHS would replace last computer in Johny O'Groats walk in centre, it would be already obsolete in the eyes of Microsoft and with them, manufacturers and devs writing drivers and so on.
And there isn't viable alternative. Insurable Linux? Red Hat - is even worse - RHEL5 was only released in 2014 and it's already EOL. Just three years later. With no direct upgrade path.
or you know design new software.
Mri also doesn't hold customer data, so don't have it on the larger network or connected to the internet.
apart from extended support is 5 years after those dates you given, but don't let facts get in the way. Oh and w10 is past those dates as long as you keep it upto date, with every new update it gets extended.
Vista was released 2006 and has just ended support.
It probably would need to be hooked to N3 though to get the scans onto the patient notes.
The caveat is that they have to pay for the extended support no?
Fair play to whoever designed this. Credit due. Bit excessive targeting the NHS, whoever did this will get a lot of ££$$ and a decent job in chaos therum.
Securing Web Infrastructure and supporting services Good Practice Guideline
4.2 Remove unneeded services/applications
If at all possible, each server in a production environment should host a single application or service only. Multiple purpose systems should not be used as it is often necessary to compromise on security controls due to the varied ways that such systems need to be accessed or the types of services which they provide need to be configured.
The following are indicative of services/applications which are found on a variety of OS’s. Any which are not required should be removed prior to placing the system in a production environment. If it is not possible to remove the service or application it should at the very least be disabled:
File and printer sharing services – e.g. Microsoft File and Print Sharing (NETBIOS), Server Message Block (SMB), Network File System (NFS), Samba Services, FTP, TFTP, RCP
