Permabanned
- 23 Apr 2014
- Hertfordshire
No more towel drying for me!
I was interested until I saw the £100 bit! Towel will do.
Are these very effective?
I've considered them in the past. I live in a very hard water area, and find it difficult to dry the car without leaving water marks sometimes.
But - it's also quite a big cost for the convenience.
I was interested until I saw the £100 bit! Towel will do.![]()
My Dooka Pad died after a few years last washTop up order today.
Shampoo: Megs Gold Class
Wheel cleaner: Blit Hamber
Foam: Autobrite Magifoam
The only other thing I need is a new mitt, recommendations?
So I've got a new microfibre madness one coming today
Guys I want to order a Das6 pro. Uses are to correct the bad paintwork on my vauxhall astra and future minor polishes of cars I may own.
You can scratch the astra paint with your nail so it can't be very hard.
Which would you choose from this lot and why?
http://www.cleanyourcar.co.uk/polishing-machines/das-6-pro-dual-action-polisher/cat_81.html
M105 followed by 205 is generally a safe bet. They do a kit with orange and white hexlogic pads on CYC.
with the hydro2 I have on the car, the rain last night just washed the pollen off completely, so a hose down would be enough
I've recently had some body work completed which involved re-spraying the front a rear bumpers and rear quarter, however this nice fresh paint has shown how tired the rest of the paint is. How long after a re-spray should I wait before going over the entire car with a DAS6?
As robbo says this kit is a very good starter DAS-6 PRO - Meguiars Hex Logic Kit .But i would get a few extra pads and a 3.5 inch backing plate with pads to go with it for tighter areas.I got the same kit for doing my nissan with supper soft paint and the megs worked well and was easy to use for a first timer.
