Absolutly torn between 2 cases, HELPPPPPP!!!!
12 Feb 2014
Somewhere Only We Know
At the moment im torn between 2 cases, I need a little advise, specifically on one of them and if someone could post a picture of something similar to what im looking to do that would be amazing.
So the 1st case im very interested in is the Corsair 460X, however, as much as I google or visit youtube, I just cant find what im looking for, I custom watercool, and what I want to know for sure if this case can fit a 360mm radiator (even a slimline one like the magicool rads) and a 240mm radiator, doesnt matter if its top or front for either radiator, but I do want both in, but if possible, I would like a push/pull config on one of the radiators, on a plus side, I love the fact this case also comes with a PSU shroud.
The 2nd choice is a Thermaltake View 31, now this will fit all the cooling im looking to get into a case, the only downside so far for me is no PSU shroud, I hate the look of un-used wiring laying around, im a bit OCD like that, the more its tucked away and hidden, the better: https://www.youtube.com/watch?v=GrZih5KTdXU this build showed me all of that, and I wouldnt be using as thick radiators as this guy, I cant find any video's or any imformation as to whether the Corsair case can fit this lot.
Any other suggestions would be great too.
How soon do you require the case? WE have some new stuff coming end of June.
And we tick the boxes for what you need.
The Corsair 460x can fit a 240mm at the top and a 280mm at the front. You can't fit a 360mm anywhere.
Also if you have a 1080ti in it the space for a reservoir is tight.
If you wanted to push/pull at the top you would need one pair of fans on top of the case. Radiator + one pair of fans inside is just short of the RAM on my Crosshair VI, and the previous board I had in the case precluded the use of 2 fans inside because of the RAM position. Push/pull at he front is a lot more doable but a front radiator arrangement would further encroach on reservoir space.
Nice case though and suits me. You could do a nice water in it with skill, but it's not really the case for a water extravaganza.
I am beginning my trawl for a new case too. Do you have any early shots of the cases that are coming?
If I showed you, I'd have to kill you!
Computex (2 weeks away) they will be unveiled. But I can say tempered glass, beauty, quality, PSU shrouds, yellow, Antec, P-Series, aluminium, vertical GPU, Tower Case, embossed thumb screws, cable management metal bracket, RGB all of the things and finally..... £74.99 and £99.99
In fact.... this is all I can give you. mwahahahahahahahahahah
Good for you man, really...I hope you get back in there. I loved my old p180, built few PCs in your cases as well, but then you kinda moved toward "gamer, flashy style"...Not for me:/ good to have quality choice :)
