- 18 Oct 2002
- Chesterfield
Thanks all.
It's just a shame that, in my experience, they seem completely incapable of properly balancing a wheel.
My "local" (about 30 minutes drive) tyre shop is superb (Martins Tyres in Woking if anyone knows it.. no one has a bad thing to say about them it seems) and I regret bothering to use Event over them not once but twice! Might be a bit far for you thoughIsn't everyone?
I am dreading the day my factory fitted tyres need to be changed
Nobody can ever manage it.
My "local" (about 30 minutes drive) tyre shop is superb (Martins Tyres in Woking if anyone knows it.. no one has a bad thing to say about them it seems) and I regret bothering to use Event over them not once but twice! Might be a bit far for you though![]()
They don't do wheel alignment. Just fit tyresDo they charge a reasonable amount for wheel alignment? I need to get my girlfriend's Mini done soon and I'd rather go somewhere that's been vetted by a group as fussy as this one![]()
Isn't everyone?
It's not surprising that a balancer that's bounced around in the back of a van all the time and isn't mounted to a solid floor doesn't work very well. With a properly installed and calibrated machine it's really very easy to balance a wheel, a monkey could do it.
They don't do wheel alignment. Just fit tyres![]()
Just to confirm, the Conti PremiumContact 6 replaces the SC5 and I should buy these now instead?
The SC6 isn't available in my size. So I should stick to the SC5?Nope the SportContact 6 replaces the SC5. PremiumContact6 is "lesser" tyre if available in the same tyre sizes.
