Fitted Eibach Sportline springs, new top mounts, drop links, brake fluid change, alignment on my..... trusty 1.8 Astra![]()
Must be time to sell it now then
 It looks loads nicer to me also. It'll do for a year (stop laughing
 )I don't, but my Dad does.Damn you work fast.
It helps that the weather is good and our "spray booth" really helps trap the heat
 Even though I have a garage November to February nothing gets done then when March hits i'm out on most weekends much to the displeasure of the missus!Nothing more demotivating than it being GREY outside.Always the case when the sun is shining.Even though I have a garage November to February nothing gets done then when March hits i'm out on most weekends much to the displeasure of the missus!
Ended up doing 4 actuallyGo for 5 coats just to be sure![]()
Superb work that, looks really REALLY well done for a "home" job.
I'll find out tomorrow when we refit the doors, I'm not too bothered on the Colour match with though as the doors, wings, bumpers and boot lid will all be done through the summer.Looks great, how is the colour match vs the doors?
Looks good in pics. Will reserve judgement til I next see it!
Looks a deeper gold than the front quarter through the sheeting, but that might just be the lighting/sheet etc.
Might need to polish up the old paint to match but should look awesome. Ginger cars FTW. Looks great in the pics and should look fantastic when you do the rest eventually. Props to you and your pops (and the old people for the use of space).
By the time I'm done it should end up being one of the cleanest mk2s in the country. Trouble is the more I do the more I find to do.
Once the paintwork and chassis rails are done I want to starting getting all the suspension and chassis bracing blasted, powercoated and rebushed
