- 11 Apr 2006
- Earth
Looking at a cheap run around for the missus and child to zip around town in. Seen this literally a few roads down from where we live. I checked the MOT History and there's a few advisories on the current new MOT when it passed. Apart from obvious tyre changes would you be suspect of the 'oil leak' and 'exhaust leak'. I'm not sure whether to walk away or not. Just need something that will last us a year.
MOT history of this vehicle
- Vehicle make CITROEN
- Vehicle model C3
- Date first used 1 March 2004
- Fuel type Petrol
- Colour Purple
- Test date 1 June 2017
- Expiry date 31 May 2018
- Test Result Pass
- Odometer reading 95,289 miles
- Advisory notice item(s)
Exhaust has a minor leak of exhaust gases (7.1.2)
Oil leak ()
exhaust rubber broken
nearside front tyre worn on outer edge and perished
Nearside Rear Tyre worn close to the legal limit (4.1.E.1)
offside rear tyre worn on inner edge and perished
- Test date 19 May 2017
- Test Result Fail
- Odometer reading 95,288 miles
- Reason(s) for failure
Windscreen washer provides insufficient washer liquid (8.2.3)
Registration plate lamp does not illuminate simultaneously with the position lamps (1.1.C.1a)
Nearside Side repeater incorrect colour (1.4.A.2f)
Nearside Headlamp aim beam image obviously incorrect (1.8.A.1b)
Nearside Front brake disc in such a condition that it is seriously weakened worn badly (3.5.1i)
Nearside Rear coil spring broken (2.4.C.1a)
Bonnet cannot be secured in the closed position (8.4.1) - Advisory notice item(s)
Nearside Front Direction indicator slightly discoloured (1.4.A.2f)
Oil leak ()
- Test date 26 March 2016
- Expiry date 29 March 2017
- Test Result Pass
- Odometer reading 92,034 miles
Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
Offside Rear Tyre worn close to the legal limit (4.1.E.1)
