My E90 has Avon tyres on, they came already on the car and are still quite new.
Are these tyres any good ?
As good as any other low-mid range brand I would imagine (unless they are the semi-slicks Avon make)
so just ride them out then ?
I personally would, although I'm sure others will be along to say that you shouldn't, you need CSC6 otherwise you will be in a ditch etc![]()
Just to confirm, the Conti PremiumContact 6 replaces the SC5 and I should buy these now instead?
Nope the SportContact 6 replaces the SC5. PremiumContact6 is "lesser" tyre if available in the same tyre sizes.
Howard was right to start with, PC6 replaces PC5 and SC5.
http://www.tyrereviews.co.uk/Article/Continental-PremiumContact-6-Launched-and-First-Drive.htm
I wouldn't choose SC5 over PC6.
17" and upwards for the PC6, 16" and below is left with the EcoContact.Didn't know that so apologies - just based it on my personal experience with premiumcontact5 that are frankly horrible. Be interesting to see if premium contact 6 are available in the size my focus takes (215/55r16).
Speed index V-Y
Rim diameter in inches 16 - 21
Tyre width 195 - 275
Series 40 - 65
Gone from Continental PS2's
Are these any good? : Falken Azenis FK510 for 225 35 19 there at £94 a tyre and it says they are normally £150.
just purchased 2 more pilot sport 4s to replace the fronts on my E92. Had the rears done a couple of months ago with the same.
Should get a few years out of them with only doing about 2.5k miles per year![]()
