- 9 Jun 2011
pretty ridiculous Intel have removed PCI-E lanes from their new 10 core
https://videocardz.com/69760/engineering-sample-update
AMD ZD1840A8UGAF4 16/32 3400 (Base) 3700 (Turbo)
AMD Eng Sample: 1D3101A8UGAF3_36/31_N 16/32 3100 (Base) 3600 (Turbo)
AMD Ryzen Threadripper 1920 12-Core Processor 12/24 3200 (Base) ? (Turbo)
16 core chip with a 3.4Ghz base clock..... i'm sorry what?
Thats not bad is it??????
I think Intel will limit the supply of those 18c parts, its just so they can say "oh we have the biggest core count" but in reality they will actually put very few of them up for sale because if they did they would cannibalise their own $9000 Xeon line up.
@ 2.4Ghz they would be slower than AMD 3.4Ghz parts anyway, a good chunk slower.
Scale that up beyond 6 cores to 8 and 10 and 12..... these are massive dies, they don't clock much beyond 3Ghz out of the factory because they are just too big.
AMD high core count CPU's are made up of multiple efficient CPU'lets, unlike Intel its not one massive die, its lots of little ones that individually can clock much higher more efficiently.
I'm going to assume its just one core XFR... because it doesn't really matter.
People are expecting Intel to knock out high core count high frequency X299 and Coffeelake chips because, well 7700K.
There is a very big difference between a 4 core CPU and already a 6 core CPU, its a much bigger die to ramp up and thats a lot more difficult, the 7700K already pulls 30% more power than AMD's 1800X and thats because while its a CPU with half the cores it is running at very high frequencies and volts to hold those frequencies. its not actually any diffrent to what AMD did with Piledriver in the 4.7Ghz FX-9590.
AMDs Infinity fabric, and stitching Ryzens together really is a stroke of genius when making high core count CPUs.
It means they can bin the cores separately, and then combine the best ones into their high end parts.
Unlike Intel who have to make monolithic cores and then just hope and pray none of the cores are defective/weak.
R9 1998X 16 32 155W 4x 3200MHz 3.5GHz 3.8GHz +100MHz
X299 Skylake X is clocking like a monster on Ambient. Well at least the 10-12 cores are. QS ES 14-18 not ready yet. So believe me Intel can easily reach and way outperform what Thread ripper is offering in terms of clocks and performance. Obviously the cost will be higher even for a lower core count.
Man they will clock good dont you worry about that. Intel are not playing here. I am talking all Cores 24-7 prime non-avx stable. I dont run any benches on X299 Skylake X CPUs that don't benefit high cores and HT. 12 Core 5.9ghz LN2 NO PROBLEM.... Remember 8 Core Ryzen is struggling to hit more than 5.2ghz+ under the same cooling and benches............
LN2 and high overclocking means nothing. if they cannot do it on decent air/Water. but if you want just a few hundreds Mhz go for itgod damn it this means coffee lakes probably going to be more than the normal jump. arrggghhhhh ile nd up flipping a coin at this rate to which way i go i bet.
Well even if it was at most 5-10% improvement, it still means that Kabylake X and 6 core Skylake X are rather pointless to get now. You can save money and get a much better Coffeelake end of the year.
well thats what my original plan was tbh, wait for august and see what coffee lake can do. but with possible upgrade paths being more probably on ryzen as in not buying another mobo and just a new chip in 18 months i was also mulling that over. no matter what wont be buying until august.
and yeah iv said it elsewhere that i think intel dropped a clanger with kaby lake x as coffee lake should come out and beat it hands down for less money, and like wise for lower core count skylake x cpu's.
