- 18 May 2010
- London
This feels like the longest wait for a product launch ever!
Who says they weren't confident, and then issues appeared? Those catalogues are out out along with the Quarterly earnings reports and investor calls.
Most are estimations hence TBD, and saying broad terms like Q2 2017; like AMD's growth and future margins, and performances are discussed at those. They can't always deliver on it all though.
What we do know is Samsung does not even put out similar catalogues like Hynix, and so far the only HBM2 manufactured by them has been 1.4Gbps modules. Nothing else has appeared anywhere.
The only other information we have on Samsung's latest is that the Tesla V100 specs show HBM2 at 1.76Gbps.
Nevermind Hynix failing to deliver on their own roadmaps and catalogues.
Remember Vega DOOM demo was from December last year, showing performance equal to an overclocked GTX 1080. Surely if HBM2 was in ready supply we'd have those cards?
https://videocardz.com/64706/amd-vega-doom-4kultra-gaming-performance-demo-possible-specs
https://videocardz.com/63700/exclusive-first-details-about-amd-vega10-and-vega20
Even back then Vega was stated to have 512GB/s memory bandwidth according to AMD employees at the AMD Tech Summit. To get that Vega needs 2.0Gbps HBM2.
Yet THE best Vega card for specs, from leaks, previews, demos, engineering samples, and Apple, shows under 512GB/s. The best is Vega Frontier at 480GB/s, and Apple's Radeon Pros Vegas will only have 400GB/s.
AMD needs every advantage they can get, and if they had access to 2.0Gbps as per their original Vega spec, they'd be using that on their Halo product launching end of this month.
Either way it not a mass production problem, it is a problem with the actual design of the component. Maybe that is what you meant but that's not how i read your post or the people before you.
I stand corrected, I was not fully aware of how yields work. But this raises more questions. Would they not be able to calculate expected yields after a few test runs?With microelectronics you run in to yields. You design the chip to be made on a particular process and you design it to have particular capabilities but you know not every chip will be perfect so one chip design can fulfill a place in a range of products. A single chip design gets tested and "binned" based on what it fails on. Good yields mean more of the higher spec chips can be sold, poor yields mean you struggle to make enough of the high spec which means the cost of those high spec modules is higher or not available in volume.
Also there is a difference between mass.prixtion and early sampling. A new product like memory will start off with one machine setup to produced it, and often a smaller machine that has far lower capacity but more flexibility and ability to essentially debug and tweak.
In time the producer can increase production capacity be re-tooling more machines and optimizing the process so instead of producing x-parts per week they can produced 20x or more. A product may have difficulties going into full production.
If they can surely they would have been aware that they are unable to produce enough high spec chips? And therefore it shouldn't have even made it into the product catalog?
Single good/full specs meeting GPU per wafer basically means it costing thousands.That's certainly a good argument.
Look at even NVIDIA with Volta. Jensen claims they can get about 1 good V100 GPU from a wafe, hence them taking preorders now. Essentially built to order.
Aren't you describing prototyping, rather than off tool samples.
Because as interesting as the topic would be, I simply don't have a lot of time to spare shifting through useless and or outdated bits of information on google to find the answer i'm looking for with such ambiguous search terms. You could have at least named the process which D.P. is referring.You could just google chip production and yields and read up on the subject.
“Designing microprocessors is like playing Russian roulette. You put a gun to your head, pull the trigger, and find out four years later if you blew your brains out.”
Nonsense, the super efficient Netburst architecture powering the Pentium IV will hit 4GHz before 2003 and scale to 10GHz by the end of the decade! AMD will be finished!“Designing microprocessors is like playing Russian roulette. You put a gun to your head, pull the trigger, and find out four years later if you blew your brains out.”
(For anyone wondering yes that was Intel's planned roadmap in 2001).
This isn't remotely feasible. AMD nor anyone else can or will block how you use their products or what companies or individuals can make software that interacts with their hardware.AMD need to block cryptocurrency mining on Vega.
If Vega turns out to be brilliant for mining then apply will not exist for gamers. This will be bad in the long run.
Maybe only allow it on professional cards.
The 570/580 Polaris cards are not in the hands of gamers and so AMD has bo presence currently in the gaming market.
Not really no. It's suggesting that AMD and nVidia are essentially going to be able to stop any future software that they don't like, from working on their card.Just like Nvidia technically supporting freesync but not allowing it you mean?![]()
