For those who asked me the case is a "be quite Dark Base Pro 900"
I'm sorry I am an idiot and I feel bad. Thanks all though, all sorted
For the video card yes I'm checking if it has been correctly installed as it moves a bit, will sort it with the support eventually
It is in properly but due to the weight they tend to flex the PCB.
Apparently it's fine and the sockets are designed to take it but I've never liked the look of it so usually bodge a way of supporting it.
Overclockers won't do that though as it looks terrible![]()
Why do they stick the ssd behind the mob tray anyway?
All my HDDs and ssds are on the back side of the caseWhy do they stick the ssd behind the mob tray anyway?
Just the way it's designed. Better airflow.
Some cases actually have that built into their design!
Or you could get an M2 SSD which goes on the back of the motherboard which is all kinds of voodoo!![]()
