16 Jun 2017 at 12:47 #1 larryddd larryddd Associate Joined 22 Apr 2009 Posts 594 Hi has anyone had any problems playing skyrim and fallout 4 on widescreen.thanks
16 Jun 2017 at 12:49 #2 MooMoo444 MooMoo444 Man of Honour Joined 4 Jul 2008 Posts 26,468 Location (''\(';.;')/'') By widescreen do you mean 21:9? I had issues at first but download flawless widescreen and it should fix your UI issues.
16 Jun 2017 at 13:00 #3 larryddd larryddd Associate OP Joined 22 Apr 2009 Posts 594 thanks for your reply is that the same for all widescreen models are any of the newer ones better for skyrim
16 Jun 2017 at 13:18 #4 DaleTheWhale DaleTheWhale Soldato Joined 17 Aug 2012 Posts 6,592 Location Tamworth, UK Flawless widescreen is your answer to most games where they need 21:9 fixes, been using it for years now.
16 Jun 2017 at 13:27 #5 larryddd larryddd Associate OP Joined 22 Apr 2009 Posts 594 so there is a problem with those 2 games
16 Jun 2017 at 14:32 #6 Glanza Glanza Soldato Joined 13 Mar 2007 Posts 15,842 Location South Yorkshire FO4 will work but when your in power armor the UI is still stuck in 16:9 unless someones been able to mod that since I played.
17 Jun 2017 at 11:39 #7 FloppyPoppy FloppyPoppy Soldato Joined 27 Jan 2012 Posts 8,153 Location The king of the north! Glanza said: FO4 will work but when your in power armor the UI is still stuck in 16:9 unless someones been able to mod that since I played. Click to expand... i am pretty sure a mod was released to fix that Also the "truBy9" mod works and fully fixes 99% of 21:9 stuff.
17 Jun 2017 at 13:33 #8 larryddd larryddd Associate OP Joined 22 Apr 2009 Posts 594 thanks for that link harry5522 I notice a similar one for skyrim on nexus.
