Status
Not open for further replies.
21 Aug 2006
How do people wash inner door sills/other paintwork for which the doors/boot/roof need to be open, as obviously I can't spray the inside of the car with snow foam :D Just a light touch two bucket wash and wipe dry with a towel?
31 May 2014
Something like Bilt Hamber Surfex HD with a spray applicator - squirt on, leave a few mins, rinse off, dry. At least that's what I do.
Caporegime
23 Dec 2011
Northern England
Open said appendage, knock the hose power right down to get rid of the loose then just go over it with my mitt. Rinse off. Dry.
1 Jul 2003
There's a voice that keeps on calling me.
Guys, need some tips on removing hard deposits from my wheels, the car is less than 12 months old, but having dar alloys has meant i havent been cleaning them as thoroughly as i should have (as i you cant really see the crap), and in the corner of the spokes ive got some buildup that wont shift with my bilt hamber cleaner, so rather than get some acidic wheel cleaner, is there a gentler way of cleaning the crud?
23 Oct 2013
Herts, UK
Guys....
Im after some microfibre clothes, you know for general usage, cleaning glass, dash etc etc
Also i've used up my QD so after some recommendations, Chemical Guys Hybrid and Dodo are the ones ive just been through, anything else out there worth trying?
16 Sep 2014
West Yorkshire
Guys....
Check out the ragmaster website, always been happy with their cloths. Wouldnt bother with Kirkland, they are poor quality.
29 Jul 2011
Near Northants / MK
You need something wrong, so acidic or alkali. Don't be shy, the stuff gets a bad name because it's used incorrectly, your use is correct. Don't let it dry and you'll be okay.
Guys....
Listen to this guy, I love RagMasters towels, kirkland are for my engine bay cleaning or exhaust :p
Status
