Are you using the metal bracket that comes with the monitor?
yes I tried it. But its definitely thinner at the lower edges. The stand incorporates the curved profile of the monitor and the bracket is flat. This makes the lower two screws stick out by roughly 3-5mm when screwed in fully.
I would usually message Acer directly in the first instance but I imagined OCUK may have provided an answer sooner
