- 25 Nov 2011
- The KOP
So you missed the whole issue of the pumps emitting a high pitched whine and months later after amd had claimed they fixed the problem, it still existed. It was basically luck of the draw if you got one with it or not. I had 2 cards close to launch and both had it, and nearly a year later another couple for other builds and they also had it. Plenty of youtube videos on it and tech sites talking about the issue, not sure how you managed to miss it as it was something that was mentioned in quite a few reviews.
Example
It might not sound like much in the videos but in person it was immediately noticeable and got annoying fast.
Don't think he means that while I agree the pump noise was really bad and is the main reason I didn't get a FuryX. The performance from the cooling was still excellent and kept the GPU really under control.
