- 17 Jun 2004
- Swindon
Nearly went for them, then hound the Deore's I already have for £99 for a full set, then thought, 'I should just really replace the dodgy caliper I have', which is £25.
Was runnning almost 10 year old juicy 3's so thought it was about time for an upgrade. Hope your new caliper does the trick.
For not a lot more you could have gone for the M8000 XT's!
Local tail running beautifully after this warm weather! Damn rain tonight tho
Considered that but don't like spending money at the best of times and only do some light xc for which the xt's seemed a bit overkill.
