Caporegime
- 18 Oct 2002
I personally refuse to believe that AMD have taken such a step back from Fiji, and that the stepping rumour (or similar) that we heard about earlier is true...
I don't think it is a step back, just not a step forwards. Clock for clock it looks similar to FuryX.I personally refuse to believe that AMD have taken such a step back from Fiji, and that the stepping rumour (or similar) that we heard about earlier is true...
Somewhere there should be another 20-30% performance. It's hard to believe that can be drivers after all this time . I know AMD is slow with driver development but this doesn't add up.
It's definitely a possibility but until someone runs monitoring software it can't be answered. Again though if it's not it's pretty misleading. All previous cards have been close to max boost and usually pretty constant. The cooler could be crap as previous AMD stock cooling has been but they still usually get close to max. Putting the fans to max for benchmarks is what i would do and as the people are not professionals and not giving out a full on overview i am not sure why they wouldn't have tried this to see if thermals are a problem. Honestly think the performance is not there for whatever reason. Bring on Rx Vega as AMD should explain why it's faster if there's a big gap. Trying to get my mate to hold out but he's put down a Pre-Order on this. Over a grand for 1080 performance , it's a good upgrade on his 290x 8gb as he has 2 but crossfire barely works in the games he plays. With the Freesync 4k monitor it should be a good step but it's far to much money.
That iswhat Makes this crazy,What were AMD expecting to happen?I think we should take this for what it is, and judge Vega when the gaming cards are released. I'm pretty astounded that AMD let it get to this though, random people benching the hot and loud FE cards just to get a glipse of the performance that everyone is desperate for. You'd think they'd want to control the situation a little better...![]()
AND officially said typical clock speed of 1382MHZ for air cooled FE. If you take that figure then they performance numbers get closer to believable. That puts FE at slightly lower FP32 performance than a 1080ti, and and care have recently always required more brute force for the same performance as NV (just comparing Maxwell and Pascal).
So if there had been no architecture improvements and Vega can only hit 1382 in gaming then things start to match up. The question then becomes why is there no architecture improvement, or if there is what else is limiting performance. And why can it only maintain 1382MHz at 300w.
I think they are having problems with there new primitive shaders. My guess is that they are trying to get it working across all games and are finding it tricky to have it running optimally.
Great so it's a slightly cheaper (presumably), hotter, GTX 1080.So over 300watt - sometimes almost 400watt for the FE card under a reasonably heavy gaming load according to this guy streaming :S
And probably not consume 400 W at the same time.For me at 1600mhz i just can't belive this card being so slow. If it is then everyone should be getting the sack. On a node shrink fury x with HBM 2 would most likely be doing a better job.
Year it's pretty dumb judging a GPU based on a professional version that AMD have stated isn't as fast nor as optimized for gaming as the RX Vega version is going to be. This is more like a proof of concept and money grab from AMD and probably not representative of what to expect in terms of actual performance from the RX Vega. Don't like the high power consumption though.I'm not sure why everyone is singing from the same AMD doomed hymn sheet. The FE is a card none of us are buying, it's not the gaming card and is being shown off by what appears to be slightly amateur hour builders or gamers. I'm not judging to hard until RX Vega arrives.
Firestrike burns the whole CPU.
i would be happy with 1080 performance but this late in the day i would expect better pricingWould people be happy with 1080 performance at 1080 prices out of curiosity?
It'd have to be like £300 if it's a very late GTX 1080 that uses way more power. Still early though, it's possible performance will improve with official reviews.i would be happy with 1080 performance but this late in the day i would expect better pricing
The primitive shaders needs the driver to have game specific update. Sort of like the game ready drivers. They will work without it, but will be loads faster when optimized.
