Man of Honour
- 21 Nov 2004
Prey works fantastically on this.
It's fine for me with a grid game I bought for the link. For rocket league I had to dial the gfx details right back. Not sure if that was a cpu or gfx card bottle neck...That is your problem right there. I ditched mine. Too much lag. Speed was good, latency was terrible.
Couple of questions about this device.
1. Can you get your PC to switch on *and* off via the controller plugged into the link? Or do you have to manually switch the PC on, trot down stairs, play your game, then trot back upstairs to switch the PC off? Does this rely on you setting the PC bios to switch on over LAN, or does the steam link box work completely outside of this? I ask because I've never been able to get my PC to switch on reliably over LAN activity when I want it to for other stuff. Getting it to shutdown remotely was also a mission, but I am guessing this would be easier with the Link cos you can actually see the windows desktop and shutdown from there? It's more the switching on thing I am bothered about, what with being terminally lazy.
2. How much of a phaff is it in practice if your main PC monitor in 2560x1440 resolution and the Link is 1920x1080? Do you have to change settings in game every time you want to use the link, or can the device scale down to 1080p by itself before sending the signal over ethernet, if you leave the res at 1440p? And if it does try to scale down, is the picture actually worse than if natively set to 1080p? What about windows desktop res if left at 2560p, is this an issue?
im assuming most of u guys who use this have the PC in another room?? if so whats the advantages of this over say a long HDMI lead ( bar 1 less cable )???
im thinking about moving the main PC into the bedroom but having the ability to connect to the big tv in living room for when the children play there games.
that would have been my next question regarding controllers but thnx for answering that as well.I have about 20 metres between my PC and the TV, so power line adapters and Steam Link are perfect. The other thing is I connect all my four controllers to a USB hub that's connected to the Steam Link.
i guess at £11.99 just now on sale its really a no brainer.
im assuming if i purchase through steam they will deliver direct from uk stock????
thnx, so shouldnt take too long to be delivered. i had visions of it coming direct from americaMine came from mainland Europe. That was a while ago though.
Mine came from Holland, I ordered on saturday and it arrived Thursday, it was despatched on the Tuesdaythnx, so shouldnt take too long to be delivered. i had visions of it coming direct from america
In case anyone didn't know if you have a 2016 onwards Samsung 4k TV. If you change your region to USA you can download the steam link app and directly run it through the Samsung TV without the box. I believe Xbox 360/One controllers work plugged into the TV too along with Steam controller.
