acer x34a does not fill screen
1 Jan 2007
hi all, i have just got the acer x34a 21:9 monitor, it looks great does not seem to have any blb, only problem i can see atm is that the screen does not go to the edges, any ideas how i can fix this would be appreciated.
Yeh that's how it is. The actual physical bezel is really thin but the picture doesn't go right to the edge.
yeah cheers for that, i expected it to go to the plastic edge which it dosent, oh well that's my only gripe, and i cant really tell the difference between this and my 165 hz predator, so all good
Yeah its a marketing technique, this enables manufacturers to label monitors as "Ultra uber thin super duper bezel".
Its Sneaky and it would be nice to have the x34a all the way to the edge but I dont really notice it anymore on mine. :)
Owned both 34" and it's the same, some people notice it straight away others don't until it's pointed out to them. I learnt the hard way due to bugger all bezel at the ends if you tip it over it'll land on the panel first and smash.
Took me a while to notice it when I got mine, but doesn't bother me in the slightest tbh. Certainly far preferable to a thick chunky physical bezel.
have they got the top bezel straight now or are they all still wonky / rippled ?
