- 17 Jun 2004
- Swindon
Nearly went for them, then hound the Deore's I already have for £99 for a full set, then thought, 'I should just really replace the dodgy caliper I have', which is £25.
Was runnning almost 10 year old juicy 3's so thought it was about time for an upgrade. Hope your new caliper does the trick.
For not a lot more you could have gone for the M8000 XT's!
Local tail running beautifully after this warm weather! Damn rain tonight tho![]()
Considered that but don't like spending money at the best of times and only do some light xc for which the xt's seemed a bit overkill.
