- 13 Jul 2004
- Stanley Hotel, Colorado
In theory you can mine with a pencil and an old envelope. Some clever maths guy worked out his hashing ability to do this. Had he arrived days after bitcoin was invented he'd even have a use, to submit his ideas manually travelling to a library to submit.
There is an official TCP over carrier pigeon protocol/usb stick also
Its not impossible he'd solve a block and gained 50 coins as reward, unlikely but protocol allows for very easy difficulty and some people are amazing at maths. 50 btc now had he kept them till now would have meant he was paid over $3,000 an hour for his work.
Silly but bitcoin is open source and anyone can start a copy of it and call it anything. IF the coin is used, the worth takes off. SO you can time travel back to bitcoin day 1 if you want. If fact people have done this and self mined the coin before then releasing it more openly. So they operated no internet connection for mining and made money.
Repeat that if you like, some think its dishonest but I think it resembles central banking in FIAT
Anything is possible, if you want to take an interest its strangely possible to do well in crypto. If you meant strictly to ask about the major coins then you need to be in constant contact because you are competing to solve first.
Some coins solve a block, process transactions every 10 seconds where bitcoin allows a 10 minutes cycle hence its recently flooded with overuse. Use a 56k modem maybe or cell plan.
7950 is considered very old now but I read many admiring how well it operates, 480 is apparently optimal neither can solve bitcoin in any likelyhood
Its not impossible he'd solve a block and gained 50 coins as reward, unlikely but protocol allows for very easy difficulty and some people are amazing at maths. 50 btc now had he kept them till now would have meant he was paid over $3,000 an hour for his work.Silly but bitcoin is open source and anyone can start a copy of it and call it anything. IF the coin is used, the worth takes off. SO you can time travel back to bitcoin day 1 if you want. If fact people have done this and self mined the coin before then releasing it more openly. So they operated no internet connection for mining and made money.
