I really like the look of the 3T comfort bend but there's no budget friendly clip-on/pad bit to match them with. The Deda Parabolica seem popular with many more bar options, just not many in stock on Wiggle. Is Wiggle the wrong place to look for these? The cheapy Token TK9 is about the only one listed with lots of reviews there.?
Having been out in a bit of a headwind last night, I tried the GCN advice for getting aero - basically hands on the tops of the hoods, forearms parallel to the ground, head down, shoulders tucked in etc.
I could easily get an extra 2-4mph for no more effort compared to being sat upright. Breathing was a little more restricted, and I couldn't do it for long, but it made a massive difference. Definitely want to try some aero bars now!
Shut up, Meg.Shocker in narrower frontal area increasing speed![]()
Exactly what I'm after!Hey Roady, not sure if this is what you are looking for but I have a spare set of aero bars from when I was messing around with my TT bike position.
Cattle-bars?!I have a pair of these cheap chinese aero bars*.
I need more of a pronounced 'ski' or J type bend, to retain as natural wrist position as possible otherwise I'd probably have ordered some of them. I'll not really be doing much more than 30 mins (10 mile TT) on them when starting out.I rode the Token bars for the little Triathlon relay I did. I'd say the pads aren't very comfortable but good enough for short events. I don't think I'd want to spend much longer than 30 mins on them. There's not a whole lot of bend up if that's what you were looking for.
I've ridden like this for a while, I actually quite like pushing into headwinds like that and find that grip on the hoods great for powering on with. I've got quite short arms so riding like that and dropping my elbows my chest is equally as low as riding in the drops. Maybe even lower!Having been out in a bit of a headwind last night, I tried the GCN advice for getting aero - basically hands on the tops of the hoods, forearms parallel to the ground, head down, shoulders tucked in etc.
He's amazingly aero for a bigger guy, he's got guns and big shoulders yet look how well he's able to roll them inwards to be as aero as possible. Total pro!I just make my own aero bars à la Sagan...
I'm similar, I generally find when in the drops I have my arms very straight, almost elbows locked. Any bend my knees hit my chest and I'm very compressed, this is about as low as I can reasonably/comfortably get:It definitely felt lower than being on the drops - can't find a comfortable "low" position being on the drops, probably because I end up being too compact, it's ok with straightish arms, though for a bit of a rest from the wind.
I found some of these for sale local to work so I'm going to give them a go.
