 - 30 Dec 2014
So I've had my upgraded build for a couple months now and I ran into this problem a couple weeks back and haven't been able to figure it out myself and was wondering if anyone knew what was up.
So the problem is this, when I try to power down my rig (Windows button, Power, Shut down) my rig will power down and after about 1-2 seconds of being powered down it'll power itself back up to the Windows log-in screen.
Everything runs fine on the PC, gaming, browsing, editing videos, etc. I've took it apart today and rebuilt it and the issue is still there.
I can power off the PC by holding the Power button on my case, but it won't turn back on unless I flick the power switch off and on via the PSU (I do have to wait for the LEDs to turn off for this to work) and that got me thinking it might be the MOBO?
Here's my spec's;
Ryzen 1700x
Asus Prime x370-PRO
Dark Rock Pro 3 cooler
16GB DDR4 corsair vengeance (8x2)
GTX 980
Super Flower Gold 550W
Windows 10 Home
Any help would be grateful. Thanks.
Here's my spec's;
Ryzen 1700x
Asus Prime x370-PRO
GTX 980
Windows 10 Home
 did not work for me. The coincidence of symptoms between the OP and my experience above leads me to suspect the CMOS battery, but good shout, it may help with his problem.
