- 9 Dec 2009
- Bristol
The mx5 tuning guy I spoke to about a remap said that mazda wouldn't even know, because they only use diagnostic tools not tuning tools.
And you don't think the diagnostic tools can read the values stored by the various sensors ans ECUs that show the car running outside of spec?The mx5 tuning guy I spoke to about a remap said that mazda wouldn't even know, because they only use diagnostic tools not tuning tools.
Remap = overclocking for petroheads.............with the same or similar upsides and downsides.![]()
Pretty sure every tuning person will say something along those lines to try and sway people who may be put off from getting a remap because of warranties etc. it's not their problem if the manufacturers find the remap during a check.
I've had mine at stock since 2013 and just don't see the point. It's epically fast out the box and I find all this tuning malarky just becomes a willy waving contest when the car is already very fast out the factory.
As far as I'm aware no one has cracked the encryption on the M140i yet so they are all stock.
Erm. No, they are not all stock. You can still get the likes of the JB4 for the M140i. 410 BHP with map 1. 440 BHP with map 2, but needs a fuel system upgrade.
http://www.babybmw.net/forum/viewtopic.php?t=94621
Whilst yes, the car is fast out the box. This is a relatively cheap way of releasing even more power. 400+ BHP in a 1 series is impressive numbers.
Of course there is risk involved. There is risk involved with everything though, crossing the road, or adjusting your balls, as happened on here the other day. And sure, it may put a bit of extra strain on some of the components, but realistically, its only 50 BHP or so on the engine. Not a HUGE amount more. I'm quite sure the tolerance is already built in, for the most part, simply from regional climate variations and the likes, at least for heat issues in this country.
"only 50bhp or so" is about 20%. That's a fairly significant chunk.
Yes, if they wanted to know, they'd know.No I don't think that because I've no idea how it all works
The Ecutek racerom remap for my mx5 (if I do it) offers different maps, changed via the cruise switch. So if I have 1 remap with all the bells and whistles and then another standard factory map that I revert to when taking it into mazda, would they know?
They are pretty mild out of the box tbh
