Joining Armoured Cable together.
OP
7 Sep 2008
that is all I can see
I'm going to open the junction box on the inside of the garage and show y'all a picture of what that looks like when I get a chance. :)
OP
7 Sep 2008
I think it is 3 core too
these are my mundane attempts at pics such a shame what they did to photoshop so using tinpic now which is as useless as some people I know!
is the 6mm the circumference around the wire?
OP
7 Sep 2008
photobucket I meant*
it seems they've put the earth together with either live or neutral not sure why
I wish I paid more attention to this when I got the wiring done in the whole house.
OP
7 Sep 2008
what was your theory again?
I was hoping you'd look at that and see something glaringly obvious like it's not been earthed that is your problem right there. shame.
got to be nicked slightly underground and needs repairing.
4 Aug 2007
Wilds of suffolk
theory that shielding is earthed and is nicked and causing your problems, its still possible its earthed at the other end but unlikely one end would be and the other not imo
worth just checking the other end as well I guess, you should never rule out a loose wire etc before you start digging!
OP
7 Sep 2008
so basically open the whole RCD and check whether on the RCD side the earth wire is connected in the same way?
If it Is NOT the same, then what shall I do? (rather check first this than dig up my lovely turf)
4 Aug 2007
Wilds of suffolk
If at the other end the shielding is connected to earth then its your call
If you have nicked the earth only then it could be causing the trip, disconnecting this may stop it.
But I am certainly not saying thats the right thing to do, there seems to be some dispute amongst electricians on using the shielding as a secondary earth or not. Try googling it to see the different views.
13 Feb 2012
It wouldn't work if that was the case. If you look closely the wire that has been wrapped in earth tape (grey core), and your neutral go to different points. I thought the same as you at first glance but that is not the case.
OP
7 Sep 2008
so basically the earth wire connects to nowhere!
13 Jun 2011
Thats the nastyiest looking way to terminate an armourd cable ive ever seen!
If you have a volt meter disconnect the cable (both ends) and check the resistance of all the cores to earth one by one. And then check them all to the armour one by one. And if you still dont find anything check between eachother
We test with a megger at work (500/1000v) to earth but you should hopefully be able to see if someings fubar with a normal meter.
And yes 6mm is the conductor size, will be 1.5mm armour.
Where are you located out of interest?
OP
7 Sep 2008
cheers mate sent you a message in trust.
