I just don't understand the idea of adding the extra cost of an AIO cooler when you intend to undercut your competitor. Surely an aircooler would have less RMA's and be cheaper to implement, even on a top end card?
The "custom" XTs, if available, could just be reference cards rebadged with the manufacturer name.Doesn't necessarily mean that amd have said no custom designs of the card, that really just seems to say availability for reference versions. After how fury x "premium" design turned out i doubt amd would want to chance that fiasco again.
I agree. I can't see the XTX being cheap for that reason. I think it might be the same price as the Fury X (£650) when it was released.I just don't understand the idea of adding the extra cost of an AIO cooler when you intend to undercut your competitor. Surely an aircooler would have less RMA's and be cheaper to implement, even on a top end card?
Be way too much that, if you've also got to add on the cost of a new PSU as well.
U haz top professional Photoshop skills there!!
At least its under the 90dB acceptable limit according to Watchdog.
A quality piece of software.haz a dona need that adobe rubbish ....paint.net... is dat one for me![]()
Notice you said Nvidia cards pluralWhy would I need a new PSU? I have a 1000W already, which I needed for NVIDIA cards.![]()
Notice you said Nvidia cards plural![]()
Others might though, as once you factor in everything else, like CPU etc...., may need minimum 800w.
 to show you were kind of joking but not really.Is an air cooler cheaper though, when it's got to cool a 300W card? To give you sufficient cooling to maintain similar boost clocks as an AIO cooled card, how expensive would that air cooler need to be?
I do not know the answer to that. But it sounds very plausible that HBCC can be used to map and transfer data between GPU memory. I do wonder if they would need a bridge for that, because it sounds like they could saturate the PCIE lanes with there current plans for HBCC.Could they use their new HBCC tech to create a transparent crossfire MGPU solution? That would be a killer feature if possible.....
Yep, I'm sure the tri x cooler would have handled a Fury x easy and cheaperThe Tri-X from Sapphire was designed to handle over 300W easily for example and it isn't that much more than a stock air cooled card.
Not sure which part of my post your referring to. Are you talking about using HBCC to map between GPU memory or saturating PCIE lanes, or both?It might be possible for compute type tasks but for gaming very unlikely to be possible with current GPU architectures.
