So first Rroff says the GSync monitor has poor gaming characteristics as its IPS and the FreeSync one is VA.
Hence he is saying the FreeSync monitor is better for gaming due to the panel type.
Yet all the other threads where he and is mate have derided FreeSync based on maybe one monitor compared to another one,that is not twisted gibberish.
There have been dozens of pages and pointless threads deriding FreeSync based on one or two monitors,from each,so basically you are saying those were less a comparison of FreeSync and GSync and more a comparison of different monitors??
So if you are now backtracking and saying the results are down to basically a poorly implemented GSync monitor for gaming and a better FreeSync monitor for gaming,wouldn't that hold true for some of the other comparisons??
I think what a lot of this side by side testing has proven is when both tech's are working properly there is little between them. Then you have to ask is the G-Sync with it's extra costs worth it and so far in all AMD's blind tests so far the answer is no.
oh come on, some people prefer IPS, some don't, the fact you can buy both IPS and VA panels on both gsync and freesync is neither here nor there... the fact that they could have used IPS for both is pretty telling as to what they were trying to achieve
Bit silly if what you are saying is correct as reviews will show it's real performance?Quite simply, at 4K the 1080ti would take a decent lead and people would then notice a difference.
AMD is using smoke and mirrors to hide the actual performance difference.
Oh come on - many of these comparisons were things like the Acer Predator TN FS versus G-Sync, TN, etc. you are just twisting this to try and pointlessly score some imaginary points :|
It seems when FreeSync is crap when compared to GSync is deffo not the monitor but the base tech. But the moment FreeSync actual might win,its down to crap GSync monitor implementation,but even in this AMD thread(don't see it in any of the Nvidia ones funnily enough),there are people going on about the absolute superiority of GSync,OFC not visible to you since you can't even see your own posts. In fact sadly they are imaginary to you.LOL,so what about when people were comparing that decent TN GSync monitor with one or two AMD VA/IPS ones,and then saying universally FreeSync is crap.
Now the moment it is shown that a FreeSync monitor can be actually be better than a GSync one,lets try and wriggle out of it.
I'm not sure what planet you are on but that is not even remotely close to accurate. I take it you are referring to the toms hardware blind test that went in gsync's favour, that was IPS vs IPS. The problem in that test was that the freesync range was lower, but that was pretty universally true at the time.
They even mentioned in this hardocp review that they knobbled the IPS screen on IQ to try to hide the fact the AMD setup would have had a worse image.
Its more important to see the implementation at your price range,and go on from there??
e fact why Rroff and others are getting annoyed in an AMD thread(of all things),is since they cannot universally say GSync is better,as they even have said the monitor needs to be looked at due to panel differences,so he needs to start insulting people to cover what he said.
So can we now put the whole FreeSync vs GSync,what is better to bed now?? Its more important to see the implementation at your price range,and go on from there??
No one is saying freesync is crap, people are pointing out that this wasnt an apples to apples test of freesync vs gsync so you cant make references to freesync being "better" from this test. Even the reviewer admits they stacked the test to remove the benefit of IPS. They are admitting they optimised the AMD system and then hobbled the nvidia one to make sure it didnt have any advantage. Which completely negates the entire "value" section of the interview.
You could do the same test with IPS gsync vs VA gsync and get the same results if you stacked the test in the same way.
I wish this had been agreed on earlier,might have made things less contentious!
Has VA now improved beyond IPS?
Thing is with VA - most pixel responses - especially with a panel like this one which is reasonably "boosted" are usually fast compared to IPS - where it falls down is some transitions especially from certain blacks which can be very very slow which can be annoying if you live with one every day but overall if you just sit down and quickly AB test the VA in this case will appear to have better clarity in motion:
Also you have SMTT 2.0 results of around 6ms for the FreeSync panel and over 9ms for the G-Sync panel which will be noticeable to varying degrees to some people.
Sorry, according to everything that I have read, VA is the worst of the three technologies for motion clarity. I am sure it's improving, but, IPS has improved too. If anything in a quick AB test people would notice an improvement moving from the VA to an IPS panel. And in a game like Doom, it would definitely be worse as there are lot of dark areas.
The 3ms difference is tiny, might not even exist, it could easily be caused by different equipment that each review site has access to. In reality what percentage of the population would be able to notice that small level of input lag anyway?
The overall gaming performance of the Eizo FG2421 was very good and we were pleased with what we saw. From a pixel response time point of view we were impressed by the fast transitions on the most part. True, there were a couple of dodgy transitions which were very slow (changes from black to dark shades) but most of the response time measurements were very good. They were certainly faster than we'd seen from other VA technology screens in the past. The average G2G response time was 8.4ms overall, but if we ignore those couple of very slow changes, it should have been more like 6.9ms. That puts it faster than the better IPS/PLS panels we have tested in fact. Add to this the fact the transitions were free of any overshoot problems at all and you have a great performance from the panel side of things. Sharp have done a very good job squeezing the best response times out of a VA matrix, while avoiding the need for an aggressive overdrive and resulting overshoot problems.
Well the nvdia proprietary g-sync module increases the price. That will certainly have a say in the cost and therefore the price of g-sync monitors over freesync monitors.All the talk of NVIDIA'S G-Sync tax, how many of you honestly believe that NVIDIA have any say In the price set for most of these monitors.
https://www.nordichardware.se/nyheter/radeon-rx-vega-prislapp-sverige.html
They reckon it's lots of krona
