- 10 Feb 2011
Hi I have had this monitor about 6month now and is fantastic but just a couple of questions. If I open up the menu OSD it says down at the bottom Resolution 2560 X 1440, 144hz Normal Mode. No matter what I do if I change the mode in NVidia control panel to Gsync or fixed etc it still says Normal. I also have a problem with ghosting when Response time is set to FAST but ok on normal. Even when Fast response time is set to fast it still says its in normal mode. Is this normal thanks.
Graphic card KFA2 EX OC 1080GTX using display port.
