- 8 Jan 2003
- Scotland
Yeah those are the ones I would avoid/will be removing. I guess I should have realised when they were so cheap.![]()
I fitted a couple,of these, then got speaking to some electricians who were worried about them in general.
The concern seemed to be about the fact they were always live and a potential fire hazard.
Any truth in this?
Phone chargers or PSUs do sometimes pose a fire risk though. I worked for a telco some years back and chargers for certain devices sometimes had to be recalled for this reason. You only have to replace five faceplates in your house and suddenly you have ten phone chargers permanently plugged in and turned on.No more so than leaving a phone charger plugged into a wall socket. It is not dangerous to leave a transformer connected to the mains with no load.
Got those lined up to install myself as they more closely match the MK ones (which are a fair bit more expensive) I have already. Would be good to see how they are for you.
Disadvantages of USB sockets
The biggest disadvantage is actually also an advantage, when there is no current being drawn through the USB outlets the USB socket turns off. What this means is that once you're phone or other mobile device is done charging the socket turns itself off thus saving energy.
The problem here is that once the USB socket is turned off the phone essentially believes the cable to be unplugged, the phone will then run on battery for a while, until such a time as the battery has dropped low enough that it begins charging again. What you then have is a situation where a mobile device is being charged many times through the night by tiny amounts. In the case of an iPhone this most likely means that all through the night the phone is going to be vibrating and beeping to confirm charging has begun (as iPhones like to do by default), and the vibration occurs even when in silent and "Do not Disturb" mode.
I've installed LAP double gang 3.1A USB sockets in my house. Seem to work well and were only £5 each from Screwfix.
